3D Electric Flying! Discuss all aspects of Electric 3D RC flying here!
how much thrust??
Old 11-20-2005 | 11:25 PM
wan42060's Avatar
Default how much thrust??
I`ve got a 500 grams (17,7 oz) 3d plane, how much thrust do I need, for hoovering and vertical climbing???
Wan
Old 11-20-2005 | 11:28 PM
My Feedback: (13)
Default RE: how much thrust??
About 700 grams of thrust will be OK. Of course you need at least 500 to hover, but in reality, you need a lot more to hover effectively. Even double the weight is good.
Old 11-21-2005 | 12:02 AM
all you need is a Hacker a-20-20L out runner and you will be hovering half throttle!!! i have a charger rc cr1 that weighs about 17 ounces and it will hover at half throttle!!! plus you can buy the motor esc combo for about $110!!!! can;t bet that!!
Mike
Old 11-21-2005 | 01:03 AM
ORIGINAL: BadBoy__MadMikey
all you need is a Hacker a-20-20L out runner and you will be hovering half throttle...
Really? So we simply discount his battery, esc and prop selection?
If you can't give intelligent advice, don't!
Old 11-21-2005 | 06:39 AM
tIANci's Avatar
Sed ... what they heck is your problem? Mikey is just excited and telling us what motor he has and how it performs in a hover. Sheeesh ... its RC for pete's sake not some mensa debate forum.
Wan - general rule of thumb is 1.5 times power to weight ratio or 150W per pound. You need a motor that will turn an APC 9x3.8 at about 8,000+ RPM or perhaps a 10x3.8 at about 7,500+ RPM. The Hacker A20 if you want to go outrunner is a great motor, so is the Himax 2812. If you want real all out performance for the 18 pz plane go with the Himax 2816 or Hacker A30, 25A ESC and a battery that can handle about 25A-28A continous discharge.
I got a Himax 2816 turning a 10x3.8 on my Fliton Prodigy (20 oz) and she will go vertical like a freight train and goes on and on and on ...
Old 11-21-2005 | 05:39 PM
wan42060's Avatar
so as I see it, I would have a good setup if buy an axi 2808/24, and use my apc 10 x 4.7 prop, and 3sp1 kokam 2000 mah
It should give around 1036 grams of thrust
wan
Old 11-21-2005 | 10:08 PM
Wasn't trying to piss onyone off...just pointing out that there needs to be consideration given to more than just the motor selection.
