3D Electric Flying! Discuss all aspects of Electric 3D RC flying here!
U-can-do-3d ep HELP
Old 01-19-2006 | 02:44 AM
Default U-can-do-3d ep HELP
Help!
I am getting into 3d and i picked the u-can-do-3d, just a set up question...
Would a 2s 1500mah lipo and a 25amp brush esc work with the stock 380 brushed motor??
Also is there anyway to set up a foamy with
2 aileron servos without using a y cable
i am using a 6 chanel receiver and a 4 chanel transmiter
Any help is Appreciated
u-can
Old 01-19-2006 | 05:09 AM
ca$hey's Avatar
Default RE: U-can-do-3d ep HELP
probley not on both if its the nurf plane you need 140 watts min try the stock motor with a 3 cell untill it frys then go brushless it hink you nead a 6 chanel to mix
Old 01-19-2006 | 05:13 AM
ca$hey's Avatar
to many tinnes
Old 01-19-2006 | 11:59 AM
Check out the u-can-do thread- many good tips and advice in there. A 2S will probably fry because of the current draw of the motor. And you 4 ch transmitter wont do dual aileron servos w/o a y-cable. 25 amp esc should work. im using a 35 in mine because of the extra saftey margin of the heavier duty BEC power supply on it.
Old 01-19-2006 | 01:31 PM
i saw a guy using a 2s 1500mah on a u can do 3d ep he said that it was good for weight plus he was using a brushless! even though i am using a 2s 1350mah which i used on another plane with a 370 brushed!
check out this http://www.rcuniverse.com/product_gu...fm?kit_id=3449
then click on the read more button on "john john's" rating thingy
Thanks for the advice on the dual ailerons
