3D Electric Flying! Discuss all aspects of Electric 3D RC flying here!
e-flite 450
Old 01-30-2006 | 09:17 AM
My Feedback: (15)
Default e-flite 450
Will the E-flite 450 motor work with a 37" wing Edge style out of 6mm blue foam?
I have 3 cell 1320 batteries.
I don't have it built as of yet, but I will guess 18-22 oz flying weight?
If so , which prop?
If not, what motor?
I want to use my 1320 batteries...
Old 01-30-2006 | 10:56 PM
Default RE: e-flite 450
E-flite 450 can handle a 15-25oz 3d plane and a 20 to 30oz scale plane. It should work fine. The propeller recommendation would be a 10x3.8-11x4.7 propeller and the 3 cell 1320 should work fine. Start with the 10x3.8 this will help keep the amp draw down. If you have a watt meter such as the one E-flite makes check your amps to see how many amps you are drawing. If you don't have one fly your airplane for about three minutes and then land to check your battery and other equipment.
Bevo
Old 02-07-2006 | 03:39 PM
Big Barry's Avatar
use a 12x6SF mine pulls 130 watts
Old 02-08-2006 | 03:46 PM
The 450 would be just fine, however the 480 would be ballistic on vertical.
