3D Electric Flying! Discuss all aspects of Electric 3D RC flying here!
rimfire
Old 05-02-2006 | 09:04 PM
Default rimfire
ok guy's and girls, What is the best way to keep props on this motor? I have thrown a prop every flight.
it's gitting stupid. i'm new at foamys, so the prop saver is a good thing for me but i;m a little tired of looking for props after they fly off.cant watch both prop and plane when it lets go,but looking for them in the grass blows.
Old 05-03-2006 | 12:24 PM
Iceman30's Avatar
My Feedback: (14)
Default RE: rimfire
nah...I just use the nut and washer....if your gonna hit the prop hard enough to mess it up all 2$ worth...I'd be more worried about the plane...with no power behind the prop on landing...even a plane w/o landing gear if you float it in the prop doens't get damaged
or just catch it !![:@]
Old 05-03-2006 | 05:06 PM
Chris-_-Memphis's Avatar
Default RE: rimfire
put two of the prop savers one...one isnt enough... thatll fix your problem.. rimfires are great little motors
Old 05-03-2006 | 05:07 PM
Default RE: rimfire
rimfires endbell is the prop saver with no way to mount it , other than saver metheod.
cant see a way to mount it backwards to utilize shaft end in a foamy.
Old 05-03-2006 | 05:08 PM
Default RE: rimfire
been using two o-rings,but they give up the ghost too.
when it gives up in tall grass, you gotta keep your eyes on the falling plane, and not on the falling prop.
Old 05-03-2006 | 05:15 PM
Default RE: rimfire
hmmm.. ok ... take your two black screws the bands hook on to out.. then install them again..just a few turns in till you are sure they wont come out.... the band will be hard to put back on but that will fix the problem.. ( my brother had the same problem on one of his rimfire.. i didnt that to his and it worked) mine was already set like that so i just doubled up b/c i throw a prop doing a high g's
Old 05-03-2006 | 05:37 PM
Default RE: rimfire
thanx for all the replys
Old 05-03-2006 | 06:13 PM
Default RE: rimfire
I use 3 o-rings. I've never had a problem except when a GWS prop broke in flight on me.
Old 05-04-2006 | 08:11 PM
SuperKaos's Avatar
Default RE: rimfire
ORIGINAL: Ryguy
Me too, I use 3 O-rings as well. Along with SMALL peices of clear packing taped wrapped around the threads of the screws Seemed as if the O-rings were wedging in on the bolt threads and getting cut... No problems now [:-]
Old 05-04-2006 | 09:42 PM
Default RE: rimfire
Theadlock?
