Extreme Flight Yak SP-E Manual Please!!!
TX
Can anybody please provide me with an Extreme Flight Yak SP-E manual in PDF form? I tried looking on their website, but it is not available yet.
By the way, has anybody had any issues with your wing and fuselage being warped and bent right out of the box. I am just wondering if this is normal and I will have to invest some time getting this plane straight and true with a heat gun. Did any of you guys get this plane straight and true out of the box?
Here is what my set-up will be after doing some research:
Ultra RC Brushless-20 Electric Motor
18 Amp Ultra RC Electronic Speed Control & gearbox.
Hitec HS-55 servos
Thunder Power 1320 3 cell pack
Do you think this will be sufficient? Any tips on radio set-up? I am using a JR 9303 radio so I can use flight modes (triple rates).
Thanks for all the help guys,
Bullseye
Hitec HS-55 servos
Bullseye
RE: Extreme Flight Yak SP-E Manual Please!!!
Bulleye,
Have you emailed Chris at Extremeflightrc? He can probably send you the manual. Ill be happy to answer any questions you have here.
Mike
Mike
Well now I feel like a horses %^%. I just figured out you are speaking of the ARF version and not the foam one. Disregard my last post and I have edited it . There is a build thread here on RCU. Let me see if I can find it.
Check this thread out. Lots of information http://www.rcuniverse.com/forum/m_21...eflight/tm.htm
Your power system should be fine. I flew mine at 150 watts using the Torque 22, 3S 1320 and 20a esc. It was ballistic. I setup my radio for 100% throw and 65% expo. That seemed to be a sweet spot for me.
