"Blast" EPP hingeline problem
hi guys
Has anyone had a problem with the aileron hinging on the epp "Blast" profile 3d.
A deep "V" has been cut into the solid epp as normal to form a "hingeless hinge" but mine has been cut too close to the outside and the hingeline is starting to fracture after only a few flights. I'm not even using full throw on the ailerons so there is no overstress.
I have a "Blade" with the same hinging method but no problems after two years of 3ding.
thanks junkie,,,,,,,,i do know how to fix the problem,,,,,,,,,i just wondered if i was unlucky or if others had this fault.
regards piroflip
regards piroflip
hey guys... i recieved my blast yesterday and built it yesterday, ready for maiden soon but the wind is blowing a hooley, mine weighs around 580g ... is that ok ? i ithink ive done everything right, got loads of pull on the motor i am using Emax 2215/25, jus post a few pics to show you the ready to fly last
This looks JUST like a Flash or Super Zoom!!
http://www.soaringusa.com/products/p...ategory_id=264
http://www.hobby-lobby.com/superzoom.htm
Whats the differences?
You may find 580 gms is a touch heavy, mine which I've only flown about 5 batteries is 550 gms, the CoG is too far forward so rather than cutting a second hole for the battery to find that wasn't in the right place as well thought I tried some weight at the rear and whilst I appreciate the planes going to fly differently as the CoG goes back you could just tell it didn't like the extra weight and I landed it and took the weight off - flew much nicer although the CoG's still too far forward and needs quite a lot of down elevator when inverted.
