3D Electric Flying! Discuss all aspects of Electric 3D RC flying here!
speed control
Old 07-27-2007 | 06:50 AM
Default speed control
how do i plug this speed control http://www2.towerhobbies.com/cgi-bin/wti0001p?&I=LXKBF5 to battery to discharge or to charge?
Old 07-27-2007 | 08:53 AM
Default RE: speed control
Don't connect the ESC to a charger EVER. Connect the battery to a seperate charger for cycling (charge and/or discharging). The Red plug (called a Dean's plug) is set to connect to your battery (Red is positive, Black is negative). The other wires connect to the motor. This is a "brushed controller so there are only two wires to the motor. It really does not matter which one is connect to which wire on the motor.
Hope this helps.
Old 07-27-2007 | 03:35 PM
the dean's in the speed control i put into the dischsrge or chsrge on the battery
Old 07-27-2007 | 03:41 PM
last question do the speed contro is good for 370 brusehd motor?
Old 07-27-2007 | 07:32 PM
The Dean plugs into the Battery. Yes this should be ok for a 370 brushed motor. But, to make sure check to see the maximum current draw is less than 35 amps.
Old 07-29-2007 | 12:46 PM
someone can tell me if the speed control is good>?
