learning to fly the typhoon2 3d
hi everyone,
since i have my typhoon2 3d i never had success with . so my question is why i crash every time ?
my longest flight it was 30 second !! but don't anderstand all my setting is ok and i already own a stryker f-27c and aerobird 3 and i can do what i want loop,backflip, inverted flight !! but when i try to turn with the rudder only ,the typhoon turn but not smoothly and when i push the trottle the plane always go vertical . I thing i need the basic of flying for this! thank you to read my post
g-day
i have flown my brothers typhoon 2 3d and it does the exact same thing exept i dont crash it every 30 seconds i found that it is very tale heavy so i added blue tack in the cowling at the field until it didnt go verticle every time i hit the throttle i dont know where the cg is though try puting it on low rates but not to low you want to be able to get the plane back under controle if something happens. try flying with someone that knows the plane well.
good luck with the plane
simmo
simmo
lol i think you said to me to try to put some weigth on the front of the plane right? but with the 4 stick of hot glue it should be good !! lol
