3D Electric Flying! Discuss all aspects of Electric 3D RC flying here!
Help before i buy
Old 10-24-2008 | 06:54 AM
qoisdhc oqina's Avatar
My Feedback: (-1)
Default Help before i buy
Hello, i would like a 3d plane and have heard alot of great things about dw planes, and i want to get the biplane with motor and esc, 4 servos and graphics, but i will need a radio correct?and will the dx5 i beleive?The $99.99 spektrum 2. ghz radio, will it work with this plane?
Old 10-25-2008 | 11:48 AM
Default RE: Help before i buy
Should work fine !
Old 11-02-2008 | 02:36 PM
Xpress's Avatar
Yes, the combo includes on a motor, ESC, and 4 servos. You still need a 1000-1500 mah 3 cell 20C lipo battery, blenderm tape, glue (foam safe CA is too hard, and will break easily), 5 channel receive,r and a 6 channel radio (for mixing the ailerons).
The DX5 you won't be able to mix the ailerons together, which is why you need a 6 channel computer radio, or have to use a heavy y harness.
Old 11-02-2008 | 09:00 PM
My Feedback: (-1)
ok.but how much would a 6 chanell be compared to the $100 5 channel?
Old 11-04-2008 | 08:04 PM
Xpress's Avatar
The DX6i is a computer radio, which means more programability, and the ability to have multiple model settings, so you don't have to change things in the radio for it to work with different planes. Get it now, so you don't have to buy another radio. It's $200 without servos or receiver, but you're going to have to buy a receiver anyways.
Radio:
http://www.horizonhobby.com/Products...ProdID=SPM6600
Receiver:
http://www.horizonhobby.com/Products...dID=SPMAR6100E
Old 11-11-2008 | 03:36 PM
He is right it is a little money but it will save you in the long run.
Old 11-11-2008 | 03:57 PM
-pkh-'s Avatar
Get the DX6i or even the DX7 if you can afford it. Once you use a computer radio, you'll never go back. Programming is easier, multiple memories let you set up several different models on a single transmitter, etc.
