RE: Help before i buy
Yes, the combo includes on a motor, ESC, and 4 servos. You still need a 1000-1500 mah 3 cell 20C lipo battery, blenderm tape, glue (foam safe CA is too hard, and will break easily), 5 channel receive,r and a 6 channel radio (for mixing the ailerons).
The DX5 you won't be able to mix the ailerons together, which is why you need a 6 channel computer radio, or have to use a heavy y harness.
