Charge rates >
Charge rates
Charge rates
Old 08-22-2003 | 11:03 AM
Ian.W's Avatar
Default Charge rates
Hello anyone who wishes to read this
Iv'e just bought myself a new Nickel thingy battery pack.
is there any rule of charge for theese batterys as this is my first 6v Nimh battery.
Old 08-22-2003 | 11:21 AM
My Feedback: (16)
2 X Capacity - Example: 1000mah charge at 2 amps, 1500mah charge at 3 amps and so on. 2C should give you a thirty minute charge time. Of course you can trickle charge.
Old 08-22-2003 | 11:26 AM
Ian.W's Avatar
do you rekon i should trikle chare for its fist time
Old 08-22-2003 | 11:30 AM
Yes, trickle charge the first time.
You could cycle it a couple of times after for good measure.
Dont charge on auto mode if using a supernova
Old 08-22-2003 | 11:32 AM
Ian.W's Avatar
mmmm, ive got a slight problem then, my wall charger only charges 4.8volt, my charger doesn't cycle, damn!
Old 08-22-2003 | 12:10 PM
Cactus.'s Avatar
your leads wont take 2amps let alone 3
i fast charge my packs at 1 amp max, my fast charger can do both types of cells up to 9 cell packs. peak chargers arnt much money these days. well worth the money
Old 08-22-2003 | 12:17 PM
Ian.W's Avatar
ive got a ripmax 'multi 12' or somthing like that, will charge anything, it can charge up to 3amps+.
phill: how do you mean my leads wont take 2 amps let alone 3?
also will my standard switch handle 6volts?
Old 08-22-2003 | 12:24 PM
Cactus.'s Avatar
your swith can take many hundredes of volts, just not current.
think of current as water in a pipe, you can only force so much water down a small pipe. the leads on flight packs are quite thin and cant take that ammount of current. the plug is even worse.
on 1.5amps the leads start to warm up, thats why i stay at one amp. the switch dosnt take the current anyway because the charge lead is soldered directly to the batt lead.
btw.. heres what happens when you dont adjust your charging amps from car racing the night before and charge at 5amps
Old 08-22-2003 | 12:27 PM
Ian.W's Avatar
i've droped cyno on many a switch and blown up many chargers
Old 08-22-2003 | 12:38 PM
Cactus.'s Avatar
ok, lets explaine why 6v makes your servos faster...
the voltage is your potential.. the higher the voltage the more push you can have, with 6v you have more force on the current than at 4.8v therefore your servos can use that voltage to force more current through the motor and make it work faster and harder, however, a 4.8v pack will last longer than a 6v one because it's not pushing as much current ( so check your plane more often ) the wires and hardware in the plane will easily cope with the current 6v will produce under normal loads. 5 stalled servos might heat things up a bit tho.
get a peak charger that can do both ni-cad and hydrides, up to 9-10 cells is good too incase you go electric. something like the Hi-tec charger would be good. does your glow starter too.
as for discharge, dont discharge the flight packs at more than one amp. the cells can take it.. the wires cant
Old 08-22-2003 | 12:56 PM
Ian.W's Avatar
yes i get all that, but why do i have to slow chare it first? cant i just fast charge it a 1 amp then cycle it a few times?
Old 08-22-2003 | 01:05 PM
slow charge it at c/10 or 165 ma for 14-16 hours, the cells are new and unbalanced, if you charge it at 1 amp for the first charge you run the risk of overcharging cells in the pack. also nimh cells take a few charge/discharge cycles before they reach full capacity. and as said above dont charge/discharge at more than 1 amp. sanyo specs say max charge input should be 1C or 1650ma, and to check capacity discharge at 330ma to 1 volt per cell. in other words if your charger can discharge, do it at 300 ma and set the cutoff at 5 volts. heres a link to the PDF specs of that cell http://sanyo.wslogic.com/pdf/pdfs/HR-AAU.pdf
Dylan
Old 08-22-2003 | 01:10 PM
Ian.W's Avatar
mmm, how about charging with my feild charger for 10 hours, or is thet unsafe?
Old 08-22-2003 | 01:57 PM
Well the feild charger for 10 hours will be OK if you have a trickle charge setting...
Set it on trickle and let it go!
if you set it to peak charge.. it will charge at the higher rate...
Not so good for a 1st charge.
Old 08-22-2003 | 02:02 PM
Ian.W's Avatar
mmmmm, i'll give it a try
Old 08-22-2003 | 05:39 PM
Cactus.'s Avatar
mine is able to get low enough on the amp dial to charge at under .2 amps. if i had no other choice...
didn't think about the wall charger... was gonna get a 6V pack for my latest. ummm
Old 08-22-2003 | 05:41 PM
Ian.W's Avatar
well, i fell into that trap phill, and i just whent out to the garage to inspect the garage, apparently it was 90% full, crap, i hope this hasn't damaged it
Old 08-22-2003 | 05:48 PM
Cactus.'s Avatar
why did you have to go and inspect the garage and whats dammaged? whats was 90% full, the garage? sounds like ours lol
Old 08-22-2003 | 05:53 PM
Ian.W's Avatar
doh, the battery
Old 08-22-2003 | 06:13 PM
Cactus.'s Avatar
so, it was 90% full and you.........?
peaked charged it? ah well, thats that well and truly........charged then
Old 08-22-2003 | 06:21 PM
Ian.W's Avatar
no, i din't press the fast charge button, i'll cycle it a few times tommorow, see what happens
Old 08-22-2003 | 06:31 PM
Cactus.'s Avatar
ah well, its knackered then throw it in the bin, better yet send it to me and i'll do it for you. you plugged it in but didn't push go, OMG its toast, your lucky you didn't blow up the house. i would have seen the flash from here. LOL
silly, all you did was trickle it, you could have left it like that for ages.
Old 08-22-2003 | 06:33 PM
Ian.W's Avatar
god, you got me worried big time there
