Help!
Old 04-25-2002 | 06:11 AM
JBH
Banned
Default Help!
Originally posted by Divesplat
If, and its hard to tell here, only the throttle another possibility may be the linkage to the carb. Believe DA put longer carb arms and 3W still has to be extended.
The solder came loose on my extension and caused something similar as the arm would catch occasionally and speed up.
Just another possibility.
Ed
Thanks, Ed. That was the kind of experience I was wanting to hear so I could rule out everything. I checked out the linkage and the butterfly... all in working order. A new radio solved the problem.
Old 04-25-2002 | 06:12 AM
JBH
Banned
Default Re: Did you ask Futaba about it?
Originally posted by robert
What did they say?
Refer to post #3 in this thread, Robert. :spinnyeye
Old 04-25-2002 | 10:27 AM
Default Re: Help!
Originally posted by JBH
Wayne... remember Mickey adjusted my throttle stick tension way down? Do you think he might have created a problem somehow?
Joe,
I dont know. He seemed like he knew what he was doing but then you never know if something got tweaked.
Send it in to be sure. Or you may just want to ship the whole package to me. Plane, motor and radio and I will do some extensive testing on it.
Sorry it took so long to see this thread but I had a hard drive failure the other day and I havnt been on RCU much the last few days.
Old 04-25-2002 | 06:42 PM
Default Re: Re: Did you ask Futaba about it?
I meant if they pinned down the problem!
Old 04-26-2002 | 08:34 AM
JBH
Banned
Default Re: Re: Re: Did you ask Futaba about it?
Oh... no, I hear Futaba doesn't set any speed records getting this stuff back... but we'll see.
