U can do 3d 46
Can you tell me the best way to make the cut outs on the items that you need to remove the monokote to attach the surfaces together??? I did try on a test piece to use a soldering iron but very poor results.... How are most of you guys doing this if using a blade cutting the monokote without danger of cutting the wood??? I appreciate any help on this and Thanks in advance.... Ken
My Feedback: (33)
just mark with a felt tip pen and i take a exacto blade and lay it on it's side and cut the covering along the mark i made. just go slow cause with the blade layed over it doesnt want to cut straight. this way thecovering doesnt get damaged.
Chad
Chad
