 Elevator set-up. >
Elevator set-up.
Elevator set-up.
Old 10-03-2003 | 11:36 AM
Default Elevator set-up.
I have not seen this done before but that does not mean it has been which is why I am seeking your advice. I want to power my elevator with a single high power digital servo. I am thinking of using two graphite control rods back to the split elevator halves but connected at the same link on the aluminum servo wheel. Something like 4-40 HD ball links stacked one on top of each other with the 4-40 bolt going through the two connectors tapped into the aluminum rod. The tubes will be the same length.
What do you think?
Old 10-03-2003 | 01:24 PM
daveopam's Avatar
My Feedback: (9)
Default RE: Elevator set-up.
Dave Brown Products makes what you need. It is made out of a fiberglass arrow shaft. You use one rod at the servo end and split at the control horn end. The shaft comes with all the fittings you need. Later David
Old 10-03-2003 | 01:58 PM
ORIGINAL: daveopam
Thanks Dave. Are you sure it is Dave Brown? Their web site has nothing on this nor does Tower show this when you do a search for Dave Brown products.
Old 10-03-2003 | 05:35 PM
daveopam's Avatar
My Feedback: (9)
I will look at the package tonight. I have always bought them from a hobby shop so I dont know about Tower.
Later David
Old 10-03-2003 | 06:04 PM
hroachen's Avatar
ORIGINAL: AV8TOR
What do you think?
I've used this method, but instead of stacking the balls on top of the servo arm I put one on top, and one below the arm. That eliminated any tendency for the balls to twist the arm. The setup outlived the airframe, never gave me a problem. It was in a 1.20 size, not a real giant.
D
Old 10-04-2003 | 08:00 PM
Ah top and bottom, that might works even better. Thanks for the reply I think I will give this a go. This will only be on a scratch design for my YS91
Old 10-05-2003 | 10:32 AM
Have you considered a pull pull on the elevator. I just did mt first on an DP edge and i may not ever run rods on my elevator again. Im very impressed w/ it.
scott
Old 10-06-2003 | 06:18 AM
I have not, only rudder. I gave it a thought but 4 cables seem a bit much just for the elevator and I am not sure I will like the looks. Pull Pull looks real on the rudder but to me not on the elevator.
Old 10-06-2003 | 09:58 AM
Cheech's Avatar
My Feedback: (19)
Try taking another look, av8or. That's my elevator servo on the left. The pull-pull runs four lines, but the look is pretty clean
It was a little hard to calculate the wire exits on the fuselage, but that was it. It's a super setup. This pic is from my DP Edge
Old 10-06-2003 | 11:42 AM
Thanks for the image Cheech and a nice simple setup. I know what you mean about the exists. This design in 3D CAD so I could lay it out there and get exact dimensions. Did you line the exists with anything?
Old 10-06-2003 | 12:10 PM
Cheech's Avatar
My Feedback: (19)
I measured the height at the servo arm, transferred that measurement to the covering on the outside of the plane. I then ran a string from the hole on the hole on the control horn to the mark. That gave me the line on the fuselage.
I then just took a swag at exactly where the cable would enter the fuselage and made a tiny slit. I got lucky and was right on the money.
