 U Can DO 60  Thrust  CG? >
Old 11-08-2003 | 09:04 PM
Default U Can DO 60 Thrust CG?
I have a U Can DO 60 with a Satio 91 can soneone give me some suggestions on where to put the CG so I can get it to preform all the manovers and where is a good starting place for the thrust[sm=confused.gif] I'm just getting started in 3D and I can use some advice on setting a plane up properly
Old 11-08-2003 | 10:41 PM
seanychen's Avatar
Default RE: U Can DO 60 Thrust CG?
CG: 5.5" ~ 6"
Prop: APC 15x4W or Pro Zinger 15x4
Old 11-09-2003 | 05:03 AM
3 degrees of right thrust on the engine, 5 3/4'' if you have the tank on the CG. 6 1/4'' if your tanks up front.
