Pilot Seduction Freestyle
I have just been given a Pilot Seduction Freestyle Kit made by the OK Model company can anyone give me any information about this aircraft such as:
Flying qualities
Best servo's and most appropriate position
Most suitable 2 stroke engine size
Many thanks in advance
Andy H
Flying qualities
Andy H
try a search for it, theres quite a lot of info on the seduction freestyle plans thread.
a guy at our club flys one on an ASP 61 4 stroke and it goes really well. He does say it could use a bit more power tho (Saito 72/ YS 63)
if you want a two stroke try the OS 50SX or the west 50.
both are very light and powerful. It will do most 3D manouvers and does really nice harriers.
The plane is brilliant!!!
Builds unlike any other i have had and flies almost perfectly. Only complaint i have is that the upright harrier is unstable, but everthing else is performed beautifully and precisely. Very stable in a hover and does the most beautiful knife edge spins you will ever see. Knife edge loops are performed with very little effort.
I would say that as far as engines are concerned anything equivelent or more than a TT 46 would do the trick. I strongly urge you to go with a 4 stroke as you will lose some of the performance of the plane with a 2 stroke. It should come in at under 4 1/2 lbs. On that note you need to take extra care that you build light as possible as the 3d perfromance of the plane is due almost exclusively to the extreme light weight. I am using hitec hs-5475's for control surfaces and am very pleased with performance of those servos with a 6v battery. You will definetly need over 70oz of torqe on tail surfaces.
You are a very lucky person indeed, a free Seduction Freestyle.
