 which 4 stroke for seduction wildstyle? >
Old 11-23-2003 | 01:39 AM
Chris-B-chips's Avatar
Default which 4 stroke for seduction wildstyle?
hey guys can recomend a brand and size 4 stroke for my seduction wildstyle. i am currently running a 50sx with a 12.25x3.75 and it uses a to much power to hover so i would like the comfort of a little more pull unless you guys could recomend something.
Old 11-23-2003 | 04:40 AM
Default RE: which 4 stroke for seduction wildstyle?
Ive watched a video of a wildstyle flying on a YS 63 and it was awesome...
i would recomend the ys 63
Dean
Old 11-23-2003 | 11:10 AM
Sprink's Avatar
I'm planning on going with the Saito 56 and saving two or three oz over the YS with mine. Should not have any problems with the APC 13x4. Also considering the new Magnum 61 RFS.
Old 11-23-2003 | 05:09 PM
Another vote for the YS63. On 30% heli fuel this is a great motor. You may say 30% nitro is expensive but you can cut to the tank size to about 2/3's of what it is now and still get longer flights. The 50SX is a gas hog.
Old 11-24-2003 | 12:19 AM
wheres the cheapest place to get the 63fz
Old 11-24-2003 | 12:27 AM
STEVE LENZ's Avatar
My Feedback: (45)
Give Central Hobbies a look for a good price on the YS 63. Ps I love the plane you have I have the seduction fun fly (Profile) I wish they would ARF Yours good luck SL
Old 11-24-2003 | 12:36 AM
thanks steve!
Old 11-24-2003 | 11:19 AM
2fast4u's Avatar
I also say the YS 63!!!! It is a very powerfull engine. CENTRAL HOBBIES is always the cheapest bay about $10.
Old 11-24-2003 | 06:00 PM
Are you saying a OS 50 does not have enough power to get this thing to hover? Or pull out?
Old 11-25-2003 | 12:18 AM
it will hover but in the wind it doesn't have enough power to pull out and i don't want to use this plane as confetti so i am considering a 4 stroke for the pulling power over the 2 stroke but if you can recomend anything cheaper i will definately try it.
Old 11-25-2003 | 04:25 PM
I use a Webra 50 in my OMP Edge 540, and using a 12x4 APC it will turn 13,700. This plane will rocket out of a hover. The Edge weighs at least 8 ounces more than my WS. I had thought about swapping engines myself, but thought the Webra would be too much. What kind of rpms do you get with the 50sx? My Webra did not like the 12.25x3.75 APC.
Jon
Old 11-26-2003 | 12:22 AM
im getting around 14000 on th 12.25x3.75. i'm going to try a 12x4 and see if it makes any difference.
