 MOKI 2.1 RELIABILITY?????? >
Old 02-13-2004 | 06:06 AM
NickC5FE's Avatar
My Feedback: (31)
Default MOKI 2.1 RELIABILITY??????
Hey all, wanted to get your inputs on MOKI 2.1 motors. I recall many years ago, i heard on run and loved the sound it put out. I hate 2 strokes, but it being so large, it had a throaty sound to it. Are they as good with reliability as they are with sounds? Was planning on a GP Patty, and one of those tree pullers up front! Thanks, NIck
Old 02-13-2004 | 07:51 AM
John Wells's Avatar
My Feedback: (10)
Default RE: MOKI 2.1 RELIABILITY??????
Mine is 2 1/2 years old and probably has twenty gallons through it. No problems, starts easy, and doesn't die on me. Very reliable engine
Old 02-13-2004 | 08:24 AM
Jet Doctor's Avatar
Have both 1.8 and 2.1 Moki's. No problems at all. My 1.8 is 8 years old. Easy to set up and runs reliably. Likes wet starts if you flip it backwards. Kicks like a mule if you flick it forward when wet!!!!! Beware! Very powerful motor.
Old 02-13-2004 | 08:56 AM
tonyc's Avatar
I have 3 Moki. Two of the 180 and one of the 210. My next motor will be a Moki. Great motor. Easy starts, smooooooooth running, lots of power.
Only down side is long break in time. Think in terms of several gallons. I think this is just a sign of good quality in the manufacture of this motor.
tonyc
Old 02-13-2004 | 09:46 AM
they are great engines in the long run but they can be a pain in the butt to break in i had one on my H9 EDGE 540 and it dead sticked during break in many times.
Old 02-13-2004 | 11:15 AM
Columbo's Avatar
My Feedback: (9)
Same here. I have a MOKI 2.10 on a H9 80" cap. No problems at all so far. Very reliable. The only time mined deadsticked was when I had the high end setting too lean. I have about 5-6 gallons through it, so I guess it is still breaking in. Nontheless, very powerful motor and will go nicely with the Patty Wagstaff. Its also cheaper to run than most big glow engines. I use 0% nitro which only costs 6.50 per
gallon at our LHS.
Greg
Old 02-13-2004 | 11:56 AM
Cheech's Avatar
My Feedback: (19)
Love my big Moki. It's in it's third plane now. Starts easy with a flip, runs great, transitions flawlessly and puts out great power.
Old 02-13-2004 | 12:49 PM
NickC5FE's Avatar
My Feedback: (31)
wow, well i guess i got the answer i wanted to hear, thanks!
Old 03-29-2004 | 03:09 PM
rgreen24's Avatar
What is the high end needle vavle setting that you guys are using on your MOKI 2.1
Old 03-30-2004 | 08:30 AM
Columbo's Avatar
My Feedback: (9)
Pantherflyr,
If you get the MOKI 2.10 be sure and get the cline regulator if you want to do 3D with it. Mine deadsticked while pulling into a hover.
Since I put the cline on her, she idles and runs better than ever, and I don't have to worry about it leaning when the plane is vertical.
Greg
Old 04-02-2004 | 05:36 PM
PlaneKrazee's Avatar
My Feedback: (14)
Columbo,
Did you send your carb to Cline have it drilled out?
Old 04-02-2004 | 06:37 PM
RNick's Avatar
Make sure you put a cline on it or you will have problems. I have around 100 flights on my 210 with cline and no deadsticks. Its the best engine I have ever owned.
Randy
Old 04-02-2004 | 07:55 PM
My choice for powering anything up to thirty pounds. With 200+ flights, no Cline, no flameouts, runs like a top. They are critical with fuel line diameter and oil per centages...JIM
Old 04-02-2004 | 09:31 PM
Columbo's Avatar
My Feedback: (9)
Brian,
No, he told me the newer version of Mokis don't need the carb drilled out.
Greg
Old 04-02-2004 | 09:34 PM
Columbo's Avatar
My Feedback: (9)
Mitchpittsman,
Mine never tried to quit until I started doing 3D with it. It ran fine during normal flying. But for those who do 3D, especially hovers, a cline is strongly recommended. The muffler pressure just doen't seem to be enough in certain 3D maneuvers.
Greg
Old 04-02-2004 | 09:40 PM
Columbo's Avatar
My Feedback: (9)
How is it going Randy?
I've put 4 flights on my DP extra so far. The last two I tried some 3D maneuvers. It is a nice flying plane, but so far it hasn't lived up to my H9 80" cap. The cap seems much more stable in certain maneuvers than the extra, esepcially the harrier. I get a lot of wing rock with the extra. I am in the process of tweeking it as far as throws, trim and C.G.. Right now my C.G. is at 6 1/4 back from the leading edge.
Greg
Old 04-02-2004 | 09:59 PM
RNick's Avatar
Yea and it looked so stable on those videos of zaks. He was using spoilerons on some stuff I know. I am going to try spoilerons to see if that stops it from wing rocking during harriers and snaping on walls. Its still a good plane those are the only 2 problems I have had. Going to try to pick up a menz for it tommorow at Toledo.
Randy
Old 04-02-2004 | 10:06 PM
Columbo's Avatar
My Feedback: (9)
Have fun at the Toledo show. Try not to empty the bank !
Greg
