 Servo choice >
Servo choice
Servo choice
Old 03-18-2004 | 03:03 AM
Default Servo choice
Can anyone reccomend a servo thats light and about 5kg? I have to put 2 servos at the backend of my
2M High Society for each elevator half.....I'm trying to avoid it getting too tail heavy.
Cheers.
Old 03-18-2004 | 05:39 AM
Marcelo3DBR's Avatar
Default RE: Servo choice
How about Hitec 545BB
English Metric
Torque 4.8/6.0v : 61 / 76 oz. 4.4 / 5.5 kg.
Speed 4.8/6.0v : 0.22 / 0.17 second
Size : 1.6 x 0.8 x 1.4" 40 x 20 x 36mm
Weight : 1.6 oz. 44.5 g.
Also Hobbico CS 65 :
Torque 4.8/6.0V : 5.54 / 6.62 kg.
Speed 4.8 / 6.0V : 0.16 / 0.13 second.
Weight : 49g.
Old 03-18-2004 | 07:15 AM
I think I've found one.
Futaba S9650 digital.
weight 26Grms
4.5Kg/.11 sec at 6.0v
anyone used these? will 4.5Kg on each elevator half be enough?
Old 03-18-2004 | 09:13 AM
Try a JR 591. Cheap and plenty of torque
Old 03-18-2004 | 09:30 AM
Sprink's Avatar
I would have thought you wanted a bit more than 4.5 kg on each half.
The hitec mini digital HS5245 gives 5.5kg at 6v, weighs 32g each. The bigger sport digi HS5475 gives the same power at 5.5kg. No so quick though.
Old 03-18-2004 | 09:49 AM
I think 4.5 on each side for a direct link is fine... Thats 9 kg overall ! Depends how aggressive a flier you are I spose
JR 591 ! Have a word - that would be an insult to the model !
Old 03-18-2004 | 10:53 AM
Also means I'd add less weight that one Futaba 9402 with both digital mini's.
anyone tried Hi-Tec HS-5245 MG?
I had an e-mail from the guy who makes the High Society, he'd read this thread and reckons it balances fine
with 2 normal size coreless down the tail end....so know I don't know what to do!!!!
Maybe build the rest and think on it[]
Old 03-18-2004 | 04:37 PM
Luke 3D returns's Avatar
I THINK billy bunter has full size futaba corelesses in the tail of his. Seemed to fly alright
Old 03-18-2004 | 05:14 PM
i would use high torque futaba coreless... 9206 i think... lovely servos these ones
Old 03-18-2004 | 05:28 PM
Yeah I like the 9206 too... silky and strong
Just had a wad load of em arrive today ! Guess where they are going !!!
Old 03-18-2004 | 06:16 PM
9206 is much more torque than he want's!!
Old 03-19-2004 | 03:20 AM
whats the spec on 9206?
If its full size servo's a have a few 9402 kicking around.....10 sec and about 7kg reckon 14kg's on elevators should be OK[:@]
(bearing in mind The Boy will probably have a go at some point!!)
Old 03-19-2004 | 04:15 AM
9402 is fine Simon even for the boy, if you are using 2.
You need 6V tpo oget top spec out of them but even on 4 cells you will have enough power.
9206s are 9.5kg, 0.19 secs, on 4.8V. Im planning on TWO of these in the ass end of the C140ex
Old 03-19-2004 | 07:45 AM
9206 is a expensive servo . It costs $89,99 on tower hobbies, it´s the same price of Hitec digital 5945 that is much better.
9206 specs :
SPECS: Speed: .19 sec/60 deg @ 4.8V
Torque: 132 oz/in @ 4.8V (9.5 kg/cm @ 4.8V)
Length: 1.6" (41mm)
Width: 0.8" (20mm)
Height: 1.5" (38mm)(without the servo horn)
Weight: 1.9 ounce (53 grams)
Hitec 5945 specs :
SPECS: Speed: 0.16 sec/60 degrees at 4.8V
Speed: 0.13 sec/60 degrees at 6.0V
Torque: 152.75 oz/in at 4.8V (11 kg/cm)
Torque: 180.53 oz/in at 6.0V (13 kg/cm)
Length: 1.55" (39.4mm)
Width: 0.78" (20mm)
Height: 1.48" (37.8mm)
Weight: 1.97oz (56g)
