Help. Need Thrust to weight ratio >
Old 04-27-2003 | 05:53 PM
Default Help. Need Thrust to weight ratio
Ok call me numb skull.
But i forgot the required Thrust to Weight ratio needed for unlimited vertical in a 3D aerobat.
Could anyone refresh my memory?
Also this is a GP Cap 232 .40 project. I have a OS .70 surpassll Four Stroke for it.
What Propellers are yall using for the best vertical?
Thanks [img]i/expressions/face-icon-small-smile.gif[/img]
Old 04-28-2003 | 12:37 AM
Banned
Best vertical performance normally comes from a long, low pitch prop. The .70 Surpass should easilly handle a 13X4, and that's where I'd start.
The .70 4-stroke is probobly going to have no problem with vertical performance on that plane... (unless you somehow make it 1 or 2 lbs overweight...)
Old 04-28-2003 | 01:47 PM
Thanks a bunch FHHuber.
Yeah i have been following the posts on several RC forums.
And i have noticed a trend on this Plane as far as overweight problems.
Therefore i have been working Hard to avoid it.
What RPM should i expect to get swinging a 13x4 APC prop on this engine?
Will keep ya posted on the results. [img]i/expressions/face-icon-small-smile.gif[/img]
Old 05-09-2003 | 04:52 PM
RaceCity's Avatar
Uhhhhhh...thrust to weight needs to be greater than 1:1 for vertical.
13-4? Where do you find one of these?
I 've run OS .70's for 15 years and they're wonderful on a 13-6 and 13-7 in most planes.
Buy a model rocket. Much cheaper, and Vertical is their specialty.
Old 06-01-2003 | 02:00 PM
Their needs to be a 1:1.5 ratio. Meaning that if you had a plane weighing 5 lbs. then you would need to choose a motor with 7.5lbs of static thrust capability. If you notice the 40% size aircraft typically have a ratio of 1:2 or a bit higher. The .70 should be enough for a .40 CAP, just remember if your building it to keep it light as possible.
