Surface Throw on 29% AW Edge >
Old 07-26-2002 | 07:15 PM
Default Surface Throw on 29% AW Edge
Guys,
How much is enough?? I've got the air-foiled tail version, and will be beveling the edges this weekend.
For good solid 3D, is there a magic number(s) on this plane? I know I can only get so much from the rudder, and I don't rely on excessive aileron throw, so I guess I'm mostly interested in how much elevator is enough. I've cut the elevators for counterbalances also, if that helps.
Thanks for any info,
Steve
Old 07-28-2002 | 12:10 AM
My Feedback: (31)
Default bevel to bevel like joe hunt!
i run the following all in degrees:
elevator 10 low 40 high
rudder 30 low 45 high
airlerons 20 low 25 high
waterfalls, t-roll, wall, blenders, harrier, and elevators are not a problems with the above high rate throws
