The worst wing drop ever
I have a problem with my CMPro KATANA 140 : when I do hard manouvers with the elevator, such as polling-out from a dive, or doing a strong negative-G loop, the wing drops like crazy! I can't realy say if it's allways the same wig, but I think it's the right one.
I checked rolling balance on the ground and it was OK. alsaw I checked both elevators (who have the exact same servo type) and they move perfectly equal, both "free" and with presure on them.
Please assist. I'm afraid of loosing the plain doing low manouvers... [&o]
do them slower, alot of planes drop the right wing if you give over 45 degree elevator in high speed situations.
if you still get it, then maybe a wing is twisted or something?
just a hunch
just a hunch
IL
I had a plane that would do this any time I gave it full up elevator when at full throttle. A little less elevator and it tracked fine. Sounds like you are experiencing a high speed tip stall on one wing. In my case it always was the right wing.
My Feedback: (21)
decrease your elevator throw until the wing drop stops, otherwise if you get in a bind too close to the ground and yank full up elevator you might just snap the the plane in the ground. usually 12-15 degrees of elevator is about max that planes of this type will tolerate before snapping in normal aerobatics, and you have to get into the 35 - 45 degree range for 3D. any where in between and the plane will fall off.
TX
all planes can tip stall.. The only plane I have ever had that won't is the ExtremeFlight Yak-54.. The GP Giles 202 25% on the other hand was the worst I had.. Heavy wings were the cause... Not much you can do but perfect your lateral balance as much as possible...
