double vision
My Feedback: (16)
MI
Does anyone know?
1 I just recieved my dv from Chief aircraft. It came without instruction. I found and, downloaded the manual from Chip web page. Are the instruction up to date. Reason I ask is when setting up the plane straight and level, I installed the horizonal stabs with anti rotation pin and stab is at 0 degree incidence with plane fus at 0. The instruction shows to lower the pin 1/8 of an inch. This will change the incidence to a negative on the stab. Is this correct.
I'm getting on answer or return calls from Chip office.
