 ca hinge gap? >
ca hinge gap?
ca hinge gap?
Old 02-08-2005 | 07:24 PM
E-Mo's Avatar
My Feedback: (12)
Default ca hinge gap?
i have a twist 3d, my right side elv hinge gap is wide enough to slip a male
servo conector( the thin side) between the two halves. would this overly concerne any of you?
failure is my fist thought <flutter> hinge tape will be used. thanks e-mo...
Old 02-08-2005 | 08:24 PM
Shawnlh's Avatar
My Feedback: (-1)
Default RE: ca hinge gap?
I think that gap may be a little big, but if you use tape you should be ok. I too have a twist, and my gaps are the diameter of the stick pin I used to hold them in place, about 1/2 mm.
Old 02-08-2005 | 09:34 PM
E-Mo's Avatar
My Feedback: (12)
thanks shawn,not much i can do now except spend another $99.00 to fix the prob...
Old 02-08-2005 | 09:56 PM
Seal both sides (top/bottom) of the elevator and fly the heck out of it.
Ed M.
