 High Alpha? >
High Alpha?
High Alpha?
Old 02-22-2005 | 06:57 PM
RichD's Avatar
Default High Alpha?
I have seen this term used a lot, and I dont know what it means.
now I really sound like a newb.
Old 02-22-2005 | 07:58 PM
exeter_acres's Avatar
Default RE: High Alpha?
alpha = angle of attack...
High alpha stuff are things that are beyond normal stall angles of attack...
ie: harriers, hovering, etc. etc.
Here is a description from www.3dfoamy.com:
You will hear people talking about High Alpha.... it is simply a fancy name for flight at high angles of attack. It means that the wing is not producing enough lift to fly. In HA flight, the engines thrust, combined with the elevator or rudders deflection provides the plane with control and altitude. It is very much like a boat in water.... air is not flowing over the wing, but rather against the bottom of it. just like sticking your hand out the window of a car and rotating your palm back and forth. The same is applied to the fuselage side.... it too can keep you "suspended" in air when combined with enough thrust and rudder deflection. To be good at 3D a plane must be able to make a clean transition to HA flight from conventional flight.... with out snapping. The key to this is large control surfaces.
Old 02-22-2005 | 08:05 PM
RichD's Avatar
ah, makes sense, now I know how the term is used, THANKS!
Old 02-22-2005 | 10:58 PM
Not to be confused with 'High Karate'
Old 02-23-2005 | 09:58 AM
Cabane,
That's too funny! Last week I was working my Funtana 40 through a High Alpha knife edge "snap to knife edge" pass, and I High Karatied the runway.
G
Old 02-23-2005 | 10:57 PM
Grasshopper. That would be brain fart. Smell simular, but don't confuse. Watch what you step in.
