 giles 202 control throws >
Old 03-15-2005 | 01:55 PM
Default giles 202 control throws
hello. does somebody know how much control surfice throw is recuires for 3D, yeas , i'm shure people will say as much as u can get, but I had 35degree and it wasn't the thing that i needed. maby i need to move cg back? my cg was over wing spar.
how is beter for 3d: cg back and less throws or, cg normal and max throws? on which setup do i have less chance to frop one side of wing?
thanks
Old 03-16-2005 | 05:45 AM
McFlyboy's Avatar
Default RE: giles 202 control throws
'frop one side of wing'?
Best would be rearward balance and max throws, but as I said in your other thread, if it's a small scale giles it'll most likely snap out before you get a slow enough speed to 3d right. For the record, I had 30-35deg on mine and it would do a wall but snap out immediately.
Old 03-16-2005 | 07:53 AM
my giles is 1600mm wingspan and weights 3.4kg dry weight. it's powered with magnum 91rfs.
