Funtana wing rock?
WY, BOLIVIA
Funtana wing rock?
I can do a harrier kinda low to the graound and correct with th ailerons and rudder but what do you guys do to make that wing rock look nonexhistant like Kyle and his funtana. does harriering at a higher angle help and do you use alot of rudder and little ailerons to coordinate a turn. I hate windy days!!!!
RE: Funtana wing rock?
You could try a spoileron mix if your Tx can do that. Like so depending on the amount of up elevaor the ailerons will go up as well. this helps me with the nise down lower but I have found the sweet spot and once its in there it sits easy .
Fly-guy
Fly-guy
Banche try movieng your cg back a bit sounds like your a bit nose heavy, or do it inverted does it much better as its acting like a high winger
blanche,the first time i flew mine it rocked like crazy in harrier,the problem was cg to far back moved the battery up to the wing tube and elimanated it completely,no mixing is required with ailerons and also even when the nose is lowering it is still steady.
mike
mike
