DA200 for TOC! >
DA200 for TOC!
DA200 for TOC!
Old 09-28-2002 | 05:52 AM
Default DA200 for TOC!
Will Chip Hyde be using DA-200 on his Ultimate Bipe????!!!!!!
Check this out...
http://www.aero-works.net/planes/ult...percent/15.htm
Four Cylinders! WOW!!
Old 09-28-2002 | 06:29 AM
mecam's Avatar
Anybody know the wingspan on that Ultimate?
Old 09-28-2002 | 09:13 AM
My Feedback: (20)
I want one!
GO DA
Old 09-28-2002 | 12:18 PM
3DMike's Avatar
4 DA 50's.. cool!! Im sure if its reliable enough and provides a greater trust 2 weight ratio than the 150, he will be using it. On other hands he doesnt want to find the teething problems halfway through his freestyle.... Im sure JAS will be able to answer that question. Are any other pilots testing with the 200???
Old 09-28-2002 | 12:32 PM
I have one in my fun-fly design, 15:1 power to weight ratio, it can prop hang at about 7/8 throttle. If I prop it right, I get unlimited verical.
The engine would probably prophang at idle actually....
Old 09-28-2002 | 01:51 PM
i believe it when are they going to offer anodized cases?
Old 09-28-2002 | 02:27 PM
rvd
wow That engine sure looks great! I guess there isn't any specs on it yet. I would love to see that baby in action.
Old 09-28-2002 | 10:41 PM
Shortman's Avatar
My Feedback: (21)
thats a nice looking engine
Old 09-30-2002 | 05:31 PM
Default DA200
Hi all,
What's the black wire going from behind the spinner to inside the motor box?
Any ideas.....
Old 09-30-2002 | 05:48 PM
Why are the wings so thin and sharp?
Old 09-30-2002 | 06:27 PM
What is up with all this ARF crap?
Old 09-30-2002 | 06:55 PM
I know....
Old 09-30-2002 | 07:22 PM
mecam's Avatar
I think by next year, you will see more ARFs in the 35%~40% scale.
Old 09-30-2002 | 07:26 PM
Remember when they used to all use home designs in TOC?
Old 09-30-2002 | 08:01 PM
Default Re: DA200
Originally posted by willembad
Hi all,
Any ideas.....
Most likely the secondary pickup. Looks like they are using a seprate pickup for each bank of cylinders. I'm probably wrong though
Old 09-30-2002 | 11:30 PM
Is that typical duct work? As tight as it is, I'm sure any air that's going in is being used, but it doesn't look like much air would travel through the cowl.
Old 10-01-2002 | 12:35 AM
Default Black wire?
If you're referring to a second timing sensor, I believe using one to be the best idea. All 4 pistons are pushing the same crank, so you'd think they would be timed by one sensor.
Any other ideas?
Willem
