Harrier Rolls
Hey guys !
I've learned to do Harrier Rolls lately but I only use elevator can anyone explain how rudder is used also? It is hard to use both at the same time...
Thanx
Thanx
VA
Get a simulator and do them as slow as you can fly. If you do not need rudder, you aren't really doing a harrier roll because the nose would fall through in the knife edge. Practice on the sim has paid off a lot for me. Good luck!
Nothing to beat a sim. I am assuming you can do slow rolls and/or point rolls if you can do harrier rolls with just the elevator. I started out the same way but the roll rate has really got to be up there for the nose not to fall out. Slow down your roll rate and concentrate a lot more on using the rudder - the elevator will come automatically. I gave the same tip to a local flyer and he practiced it on his sim and now he is doing rolling harriers all the time. So the technique does work - hope it works for you too.
From: SantiagoReg Metropolitana, Providencia, CHILE
yes, it can be done, but the attitude keeps much more clear when you use both, and you can do it slower, looks much like a pro
