3D prop question
IN
.61- 13*4 to 14*4 range
.75- 14*4 to15*4 range
I havn't actually flow those motors, and it is all dependant to what airframe and the amount of thrust you are wanting.
I run an 11.5*4 APC wideblade on a .46pro, and a 12.25*3.75 APC wideblade on an xls .52.
A good general rule is to look at manufacturers prop chart and go to theLargest diameter prop and use a pitch of half the diameter (or a little less).
What airplane will it go on? gwsdrgnfly gave some solid advice. For 3d the APC's wide series seem to work well, but many like the narrow 13X6, depending on what flavor of 3D you are doing, and with which airplane. I am comparing this to my Magnum and OS .61 engines, and Magnum .75 engine. Won't own any more Tower engines, bad experience with them, but their mufflers rock, exspecially on .46's.
ORIGINAL: woops
What's the best 3D prop for a Tower.61 and a Tower.75? Any ideas?
ORIGINAL: mikeboyd
ORIGINAL: woops
