 harrier .90 >
harrier .90
harrier .90
Old 06-24-2005 | 08:08 AM
3dman523's Avatar
Default harrier .90
I just bought a harrier 90 for doing 3d. i am 14 and been flying for about 7-8 years. I decided to get into 3d flying so i bought this plane. It has a saito 120 for power. is this a good setup for 3d?
Old 06-24-2005 | 12:38 PM
Default RE: harrier .90
yea the satio should be fine..what prop are you using?
Old 06-24-2005 | 02:17 PM
seanychen's Avatar
ORIGINAL: 3dman523
Wow, so you've been flying since 6 or 7? That's pretty good.
Saito 120 will have more than enough power for this bird. Just get the CG correct, as this is a heavier engine than called for.
Old 06-24-2005 | 04:41 PM
3dman523's Avatar
i started flying when i was 6. both my mom and my dad fly. I am useing a 18x6w prop. it is a little tail heavy but i like it that way it hovers realy good.
Old 06-25-2005 | 10:37 AM
tIANci's Avatar
The 18x6W is a little too much for the Saito 120, its more for something like a YS140 or the OS160. Try to use a 16x6 or 17x6. I just got mine ready, everything xcept for the cowling. I am using a YS110 and the plane will be nose heavy once the cowling comes on. I will have to shift my RX batt and other stull more to the back. Hope she flies well!
Old 06-25-2005 | 11:24 AM
3dman523's Avatar
they fly awesome if you have it a little tail heavy. it does harriers with out any wing rock.
Old 06-25-2005 | 12:22 PM
tIANci's Avatar
3D - I will take it as far back as I can after the maiden.
