Seagull Razzle Setup
GA
Can anyone give me any info on their Seagull Razzle settings to get the most out of it. Mine has a G75 Supertigre with Hitec gear. What I am looking for is:
Any right thrust added?
Clevis settings?
Engine Type?
Prop Size?
Front to back weight ratio?
etc....
Clevis settings?
Engine Type?
Prop Size?
etc....
hello, I fly mine with two shims under the enginemount on the left side to get some right trust, still have to trim in a little right rudder. I used to run a os 91 fx but have recently put in a sc 91 fourbanger. I use apc 14/4 w on both engines. flyes great on both, but you can`t beat the sound of the 4 stroke even though it has less power to pull out of hover, but it is sufficient. I have max deflections on all moving surfaces and the cg way back. when I fly inverted on half trottle I must give a little down elevator or it climbs.
We have one with a YS 91AC-H four stroke, APC 14x4 3D blade. (engine was originally for a helicopter, that's what the H designation is) Pulls vertical quite well, flys 3D well, but we haven't been able to fly it lately due to the engine leaking. Great flying airplane.
