H9 Edge Video Clip
#51
My Feedback: (33)
Originally posted by mecam
Oh it's rich, it's rich where it's blurbing and lots of smoke. Plus that low end knob is very sensitive to little adjustments. They can be tuned right with lots of patience which I don't have.
#52
CA
Originally posted by bodymann
MECAM
ARE YOU RUNNING A REGULATOR
MECAM
Originally posted by coony2787
a moki can be tuned correctly very quickly , USE A TACH
#53
My Feedback: (33)
I tached it at 8100 on ground with a Bambula 18x8, anything higher it leans out when going vertical.
Chad
#55
CA
Thanks guys, something to try. Also do you guys know where I can buy the low end knob O-rings. My low end knob seems loose and can be easily turned. Maybe the problem is there. One time I was flying normaly and the engine just died and when I landed the low end turned almost 1/4 of a turn on the rich side.
#56
Mecam,
Same thing was happening to my engine. I called Jim Gerard (you can get the number of Gerard Enterprises at the Horizon site under Moki) and he sent me some new o-rings free of charge. That's great customer service.
#59
CA
Originally posted by RickP
Flip,
What about the GP mount? It's all I ever used....
RickP
Flip,
RickP
SPECS: Overall length: 5.04" (128mm) Usable beam length: 4.5" (114mm)
Mounting width: Min: 3.25" Max: 4.5"
Firewall bolt pattern: 1.95" x 1.95" (49.5 x 49.5)
#62
CA
Originally posted by m.gramling
What size motor mount is that. Is that the GP 60-120 size mount.
#63
My Feedback: (99)
TX
mecam
should be able to get one at your hobby store can't find the address right now. i have one on my 1.60 and it works great provides conistant pressure at all rpm.
p.s. think there
about $ 50.00
p.s. think there
about $ 50.00
#67
NY
The above mount should be able to handle anything you guys throw at it. I have my BME 50 mounted on it in my GP PW Extra. I do not know the weight but I'm sure its less than the Hangar 9 metal mount.
#68
My Feedback: (39)
IL
No Regulator, where can I get a kline reg? I heard this works.
Link for the Cline PCFS. http://www.billsroom.com/pcfs/ Will provide constant pressure and fuel delivery.
Talk to Jim, he has lots-o-tricks for the Mokis. He can make 'em run the way they were supposed to!
#72
My Feedback: (8)
I've got a H9 Cap/Moki 1.8 that also desperately needs a diet (13.6 lbs). I didn't realize that blasted metal mount was 7 ounces. Has anyone tried that GP mount yet? Might be an easy and cheap way to shave a few ounces quickly.
Also where do you get that Yellow mount pictured above?
#73
CA
Call up www.yellowaircraft.com
