Yabbadabbadooo, OMP Edge kit arrived!!!! >
Old 12-10-2002 | 10:54 PM
Default Yabbadabbadooo, OMP Edge kit arrived!!!!
Pulled into the driveway and dumped onto the ground behind my car were 2 LARGE boxes. I must have looked like a fox in the henhouse going thru the packaging Check for any damaged stuff, none. TRU-TURN spinner and cowl, foam parts get clean bill of health.
Glass work is exceptional and lite, 35% cowl being only 13.5 oz before any trimming, it is one piece. Pants are only 4+ for the pair.
Foam cutting is excellent also, no ripples or messy servo, joiner holes.
Gotta take off to do a side job=digital servo's. Jordan will drop by with camera later in the week.
Old 12-11-2002 | 12:47 AM
I bet you are happy. I cant wait to get my carden....
Old 12-11-2002 | 02:46 AM
I have a ZDZ 100 on order for it. Will probably set it up for smoke. Have'nt decided on mufflers yet, not going canisters anyway.
I will use a single reciever but have not decided on the battery set-up yet.
I'm usually a lightweight freak but not sure how far I will go with this bird. It usually builds around 26 lbs.
Paint scheme is getting there, will try to post a wing later.
Old 12-11-2002 | 03:21 AM
Cool, I look foreward to seeing pics. If I were you I would use powerflight or duralight batteries. You can fly all weekend long on just 1 charge. Good luck.
