 6V on RX ANY PROBLEMS? >
Old 04-13-2006 | 04:04 PM
badfish's Avatar
Default 6V on RX ANY PROBLEMS?
last year I purchased a 1.60 size plane that came with a 6v noobs brand new rx battery. After charging, I believe the volts were up in the 7's and I always saw twitching in the servos till I got some flights in and the pack lost some volts. well I only got to charge the battery a few times before the plane went in. it was right in front of me hanging it and I just finished charging the battery. everything locked up and turned nose down and went in at 1/2 throttle. not pretty. I always use a reg. of some sort now. I even use the same rx that was in the plane that went in. no problems. I run JR and the receiver was a 770. anybody else notice any problems when just using a 6v battery. seems like a lot of people are using them. that incident just freaked me out, I've never had a problem with my radio before till I used the battery.
Old 04-13-2006 | 04:10 PM
exeter_acres's Avatar
Default RE: 6V on RX ANY PROBLEMS?
the 770 should handle the voltage just fine....
most Rx's can handle much higher voltage...
which servos?
Old 04-13-2006 | 04:28 PM
badfish's Avatar
5945's in the rear and jr 125's in the ailerons. I think the throttle was a 55.
Old 04-13-2006 | 04:48 PM
bodywerks's Avatar
been running regulated and unregulated 6V packs for 10+ years without incident.
Old 04-13-2006 | 05:51 PM
gjeffers's Avatar
ive been using 6 volts on my 770 for 4 months or so and have about 40 flights on my edge and no probs.
Old 04-13-2006 | 06:10 PM
badfish's Avatar
I guess I must of had a bad component somewhere that didn't like the fully charged 6v battery.
Old 04-14-2006 | 10:48 AM
I've been using 6v packs for quite some time and in conjunction with Hitec servo's. Occasionally I'll see the jitters from a newly charged pack but after letting the plane sit a few with the switches on, it all settles down. Now if you had a marginal servo, this is definately the way to find it! Sorry for your loss. I believe in the KISS principal. Keep It Simple Stupid! The more you enter in the electrical equation, the more can go wrong. I try not to use matchboxes, regs, Y's, amp's (...etc) if at all possible. Use a 6v pack and burn in new servo's. They typically go bad within the first 10 hrs if they are defective.
