 Funtana 90 Flight problems?? >
Old 11-05-2006 | 11:33 PM
Default Funtana 90 Flight problems??
Hi all,
Well I am new to the Funtana and have the original Funtana 90. It has been converted to an electric Funtana 90. but I don't like the way it flyies. Anyone have problems with Wing rock? If so how did you fix it. I can't even slow the thing down with out it rocking. The slow flight characteristic s seem to be pretty poor. Anyone else have this problem with their Funtana 90.
Old 11-06-2006 | 02:42 AM
tIANci's Avatar
Default RE: Funtana 90 Flight problems??
How slow is slow. For me my F90 came in as slow as a trainer for landings and there is no wing rock. Were you executing harriers?
Old 11-06-2006 | 07:06 AM
I have no problems with my Funtana. It will rock a little in a harrier but that is all. May want to check your CG. I am not sure if that will help you or not but it's worth a try.. I set my CG far enough back that when I go inverted I need just a touch of up elevator to keep it level. My funtana will land at walking speeds and no rock or fall out at all!
Good Luck..
LATER
PS.. What engine are you running.. You may have it too heavy!
Old 11-06-2006 | 07:44 AM
Rocketman_'s Avatar
ORIGINAL: showstopper
... The slow flight characteristic s seem to be pretty poor. Anyone else have this problem with their Funtana 90.
The Funtana 90 is well know for it's good slow flight characteristics but it is not a park flier or back yard flier.
Old 11-06-2006 | 08:36 AM
Walt and Sage's Avatar
Sounds like your electric FUNTANA 90s is to heavy
Old 11-06-2006 | 10:30 AM
check to make sure the wings are 100% true and that the ailerons and stab/elevators are not warped,and make sure they are set at center
