RE: Funtana 90 Flight problems??
I have no problems with my Funtana. It will rock a little in a harrier but that is all. May want to check your CG. I am not sure if that will help you or not but it's worth a try.. I set my CG far enough back that when I go inverted I need just a touch of up elevator to keep it level. My funtana will land at walking speeds and no rock or fall out at all!
Good Luck..
LATER
PS.. What engine are you running.. You may have it too heavy!
