Dp Ultimate Bipe >
Dp Ultimate Bipe
Dp Ultimate Bipe
Old 01-31-2003 | 03:41 AM
Default Dp Ultimate Bipe
I just finished tonight and it weigh's 12.5 lbs. Why is this how can i lighten it. Saito 150,true trun spinner, Standard size high torque servo's, 1 5cell 6v batt, everyting according to book.
and it supposed to go 9-10.5.lbs. But the balance checks out right
on the mark.
Old 01-31-2003 | 04:24 AM
flyinrazrback's Avatar
My Feedback: (69)
mine weighed 10.5 lbs with a OS 1.08 and tuned pipe, but I used hitec 225mg @ that are less than an ounce each, but still metal gear and 67oz each torque. Lithiums will lighten it up, and maybe light tires.
Old 01-31-2003 | 10:58 AM
maineflyer's Avatar
My Feedback: (44)
That is the exact setup I am looking at putting together. I am wondering if you just got a heavy one? The servos "standard vs minis" even if you went with all 225MGs only will save 1/2 oz per servo, so you would save 3 oz if you put them all the way around. This obviously would not be advisable in the tail. I willbe interested in what others have to say.
Jeff
Old 01-31-2003 | 01:12 PM
My Feedback: (31)
i have had 3 motors on mine:
satio 180 20 oz tank
rcs 1.4 gas 12 3/4 lbs 1100 nicad 600 nicad 10 oz tank
os-160 12 7/8 lbs 2700 NMHi battery 20 oz tank
rudder 8411
elevator jr 8101
jr 537 ailerons
i think i always get the heavy kits he he if i use glue
Old 02-01-2003 | 12:26 AM
Default Heavy
So is this to heavy to 3D????... Will the power to weight be enough with the saito 150, which prop, I was thinking about
16x6,or16x8..
Old 02-01-2003 | 02:42 AM
seanychen's Avatar
Default Re: Heavy
16x6,or16x8..
APC 17x6 @ 8900 rpm will just hover a 12 lb. bird. Not much more to pull out though
