what size RX batt for a Razzle 3D?
My Feedback: (17)
VA
I'm getting a Razzle 3D and will be putting a Tower .75 in it with Hitec 625's on all surfaces. Planing on a 6V system. What capacity would be recomended?
I usually just fly heli's and have gotten the urge for a fixed wing 3D ship. Not sure about the current consumption on these things. Need some numbers from what some of you others have been useing.
Thanks.
Thanks.
My Feedback: (43)
Hello Arrio, we just got ours flyin. We have an OS 91 FX in it with combo of HS605's and 2 JR 537's on ele. I like to have plenty of juice on our 3D planes so We have a 1400 MAH 6 volt flat pack in it which helped to balance it out well by putting the batt right in front of the servo tray. We ran pull pull on rudder with a 605 on the tray. Flew real well on our test flt sunday - it was cold and windy and it locked into a hover real well and did all other basic manuvers well. Did not try any real hard 3D yet , so ??? Loks good so far - lands very slow and easy too. It may be a keeper ! Have FUN , Rod & Chris in PA.
I am using a 4 cell 1650 mah RX pack. This is a NiMh pack and seems to be plenty juice. Keeps in mind, if you use a 5 cell (6 volt) RX pack, the servo's will draw more power from them than if you use a 4 cell (4.8 volt) pack. Therefore, I would go for as least the 1650 mah pack. I have 4 HS77, one 5625, and a standard for throttle.
Good Luck,
EdMan
Good Luck,
EdMan
My Feedback: (17)
VA
Thanks guys. Last night I bought online, two 5cell packs, an 1850Ma and a 2700Ma NiMH. Looks like I will be useing te 1850.
I usually just do heli's and I like to have alot of reserve power in my RX packs. So generally I run at least 2000Ma in them. I remembered that fixed wings don't usually consume as much battery, but I wasn't sure were the general comfort level was. I could use the 2700 in my choppers anyway.
Most of my stuff should in by the weekend. Plane, engine, servos batteries, props. I ordered APC props 14x4 and 15x4, Zinger 14x4 and 14x5. Hopefully one of these will work out.
I likely won't get to fly it till the following weekend. Weather is calling for rain all this weekend anyway.
Really looking forward to flying this Razzle!
