POst a picture of your 3d airplane
CA
Originally posted by WreckRman2
Was a Hitec 5625...
Was a Hitec 5625...
#38
TX
Midwest Citabria
its not a 3D plane, but i can make it do what some of the 3D planes can, after i get my aluminum struts put on, then ill push it. I can hover,torque roll, ect with her--yes its a Midwest citabria, not the wrong picture. purly lots of fun, but plan on getting a real 3D plane when I can afford it. It has dual servos on the elevator, 4 servos in the wing. one on the rudder, and powered by a .90 2 stroke. 2000 mAh NMH battery with fortress reciver and futaba transmiter. its different--and i like that.
#40
No tail touches with the one.
This does all the 3D and plenty of pattern too. It does the most incredible spin combinations of any airplane I have ever owned. Regular to flat to knife-edge to inverted flat, all in one nice drop. I'll build another soon and rebuild this one with a new wing.
Mark
Mark
#45
The Majestic
AAAA,
Thanks. It gets lots of looks where ever I take it. I did by this one RTF.
It's a kit from ZNLine, available in the USA from Central Hobbies, special order only. ZNLine takes direct orders for prefabricated airplanes to ARC, ARF, and even RTF stages (it's all custom work).
Me, I'm going to build another with the same scheme, but a color change. I'm thinking of some metallics with purple someplace in the scheme. I have to have some purple in it.
The airplane is 10.2 pounds, about .5 pounds heavier than it needs to be. The new one will have larger ailerons, no flaps. That will save significant weight. Also lighter cores.
This one is powered by the OS140RX, soon to have a swap for the OS140FI. The next will get the YS DZ.
Mark
Mark
#47
Majestic!! Oh boy what a toy
To quote Tina Turner "Simply the best" better than all the rest.
Believe it.
Only problem is the cost
Believe it.
#49
Hello,
here are my 3D-modells:
Super Diablotin with OS46 FX
Diablotin XL with ZG62ccm
Funflyer with OS91FX
High Society 3D with OS140RX
Pitts with ZDZ160ccm
Predator with OS91FX
Here is a site from a friend of me:Homepage from Sven Weinig There are acrobatics- an 3D models
Stefan Reinicke
Stefan Reinicke
