 Wide prop Spinners ??? >
Old 04-25-2007 | 07:50 AM
My Feedback: (29)
Default Wide prop Spinners ???
Can anyone give me some info on where to find some Inexpensive wide prop spinners? I know about Tru Turn but they are expensive.
Thanks for any help.
Old 04-25-2007 | 08:08 AM
bubbagates's Avatar
My Feedback: (32)
Default RE: Wide prop Spinners ???
You can cut any spinner to fit any prop.
Espirit is a great fiberglass spinner, but for smaller planes, dubro, great planes, etc come to mind. If you want CF then go to troy built models
Old 04-25-2007 | 09:05 AM
My Feedback: (29)
I have never cut a spinner before. is it hard to do right? and is there any info on the correct way to do it?
Old 04-25-2007 | 09:08 AM
piroflip2's Avatar
The hardest thing is getting both sides cut the same.
Make a template out of card and mark both sides.
Old 04-25-2007 | 09:26 AM
bubbagates's Avatar
My Feedback: (32)
As was mentioned, make a template of the prop blade and using a dremel it can be done easily if you take you time. I cut CF spinners all the time and have cut the dubro and great planes ones as well.
Here is a good article on how to do it. This is for thinner Cf and Fiberglass ones but you will get the idea
http://www.rcuniverse.com/magazine/a...article_id=528
