Twist 150 and havin fun
#53
AB, CANADA
Lets here some more on this twist 150, me and a buddy are going with this plane and zenoah 26 airplane motors with a ddm x can for pipe.
#54
I just maidened my Twist 150 today. About 10 MPH winds and the plane felt rock solid.
My servo arms were too short so I could not get all of the recommended throw but it was still pretty sufficient.
I used a Saito 180. Overkill. I would ly at 1/4 throttle or less and it would climb at anyhing above that. Oh well I am going to keep it in as I love the extra power.
All in all I had a great time. Did anyone else notice that the prebent pushrods were the wrong size? I had to rebend mine for my servos. I have a tight fit with the wing dowels also since I notice you guys are also.
Flight performence was well, for knife edges it want to roll. I broke my prop on my spinner so I had to use a smaller one but I still noticed it hovered very nicely. I am going to order one from tower so I can get back to flying. I like this plane a lot and it was such a breeze puting it together.
#56
NY
raptor 8,
What is a ddm x can pipe? If it is supposed to give you more power, I can tell you that you don't really need it. I have a stock mag G26 with a bennet muffler and it has more than enough power for anything you can possible do.
#57
AB, CANADA
what prop are you running. the x can is a ddm can for the car 26 motors and helps put out about another .5 horse. compact, easy install.
#64
My TWIST 150 is powered by an Evolution 26 turning an 18-6 wide APC at almost 8000 RPM.
Weight is 9 pounds 13 ounces with 2 ounces of balance weight in the tail
It balances in the middle of the recommended range.
I'm using the Bisson "Sport" muffler, looks like a regular 2 cycle engine muffler.
Test flying next week
#65
NY
Fired it up today and checked it with the tach. RPM was 8200. My location is 700 ASL. Temp was 67 Degrees. Humidity was 57%. Main jet is set a couple hundred RPM below max RPM.
#66
VA
Hey Dick. Are you planning on reviewing the Twist 150 any time soon? Horizon just lowered the price to $199.00 so I am seriously considering this plane with a Saito 180.
