Goldberg Matrix
Banned
i recently got a golderg matrix 3d in a trade, who has one? how does it fly? i plan on taking it out tomarrow so i guess ill answer my own questions but does it have any problems i should worry about? i noticed the ratings were a bit scatered. some hate it some love it. the review videos looks good.
scott
scott
It flies nice ...not difficult at all ... does not tip stall like some scale planes etc. Should not be a handful if you are familiar with low wong planes.
Shoehorned a Saito .91 in mine and love it - absolutely unlimited vertical and same all-up weight as with recommended OS 70FS. Placed 2 low profile servos in the tail for ele and went to pull/pull set up for rudder. Plane flies on rails like a pattern ship and has great rudder authority. Set it up right, and knife-edge loops are almost easy. If flying from grass toss stock wheels & pants. Have fun w/ it.
Banned
well i have a irvine 61 and the guy i got it from said to be carefull with the throtle or i will rip the wings off.
i would love to put a saito 91 in there man i can only imagine that power.
how much did your weigh in the end? i dont know about mine but it feels pretty heavy.
scott
scott
My Feedback: (9)
PA
I had one and learned to hover with it. Had a YS63 and it was unlimited vertical. First flight I fluttered the ailerons with standard servos. Mine would tip a wing if you pulled too hard when coming out of a loop. You either had to be smooth with the sticks, or yank the stick so it would wall right through the stall zone. Fun plane. I wadded it up trying to show off for the camera. Replaced with a Mojo profile and never looked back.
Mike
Mike
CA
I had a Magnum 91 4 stroke in mine; in retrospect my OS 70 has equal or better power than the 91 but I didn't have the 70 when I got the Matrix. I still have it but it's been decommissioned for now. My main suggestion is do not use the stock elevator setup. Use dual elevator servos in the tail. When I'm ready to fly mine again that is what I will do. Also, and OS or Magnum 91 is just not a good choice for 3D - the saito 82, Os/Magnum 70 or the obvious YS options.
Flight performance? Handles wind well, very good control authority but does show quite a bit of wing rock upright in a harrier - Inverted isn't as bad. It is a nice airplane and I have enjoyed mine. I think when I get better - it will be better.
