 3D Servo Arms >
3D Servo Arms
3D Servo Arms
Old 10-17-2007 | 06:52 PM
My Feedback: (13)
Default 3D Servo Arms
What are you guys using for servo arms? I am tuning a Hanger 9 Showtime and dont seem to have enough throw as per the manual for high rates. Wondering if there are special long servo arms made for 3D throws. Thanks
Old 10-17-2007 | 07:05 PM
YNOT's Avatar
Default RE: 3D Servo Arms
The Du-Bro 3D arms work great and very light.
Old 10-17-2007 | 11:58 PM
Airwild makes some very nice stuff too. That's what I've got on my Showtime.
Old 10-18-2007 | 03:47 PM
My Feedback: (13)
Ro:
Also be sure that you are using all of or nearly all of the ATV adjustment. Some brands reserve almost 50% of the travel available for ATV, not good for 3D machine servos to use a small part of their gear systems with high loads.
Old 10-18-2007 | 04:21 PM
My Feedback: (13)
ATV? I HAVE A 7 CAP....ILL HAVE TO LOOK AT THE MANUAL. DO YOU MEAN THE THROW ABOVE 100%? iLL HAVE TO TAKE A LOOK.
Old 10-18-2007 | 05:14 PM
mrbigg's Avatar
My Feedback: (21)
ORIGINAL: ro347
It should go to 150.
Old 10-18-2007 | 10:05 PM
some radios can drive the servo to 150% travel each way.SWB,Airwild make good 1 inch plus, aluminum horns to match your servos.The DUBro plastic ones will probaly do for the Showtime.
Old 10-18-2007 | 10:20 PM
My Feedback: (13)
OK...the "ATV" the was mentioned before is what is now known as END POINT ADJUSTMENT. Why did you just say that! Duh! Just kidding!
Old 10-19-2007 | 12:10 PM
mrbigg's Avatar
My Feedback: (21)
ORIGINAL: ro347
Different brands call it different things.
Old 10-19-2007 | 12:53 PM
My Feedback: (13)
I know. It threw me for a loop. SO what does ATV stand for?
Old 10-19-2007 | 12:56 PM
Charlie P.'s Avatar
DuBro "Long" (they come on a tree) or the G.P. Heavy Duty (up to 2-1/2" for singles!) with inserts for various makes. On anything over 70 oz.-in. I use aluminum (Futaba makes 1" & 1.5" single arm).
And I agree about trim. The better you have it mechanically the less throw is consumed for electronic trims and endpoints.
Old 10-19-2007 | 04:26 PM
mrbigg's Avatar
My Feedback: (21)
ORIGINAL: ro347
One of my Hitec radios had it. I think it means "adjustable travel volume." Not sure if that's right. Maybe somebody know for sure.
Old 10-19-2007 | 06:40 PM
ORIGINAL: mrbigg
I think it mean "adjustable travel volume." Not sure if that's right. Maybe somebody know for sure.
I'll second that.
