31% edge arf by aeroworks help
GA
I'm getting ready to put together this arf with a DA 50.
I have a flying buddy who has one with an odd flying problem.
it trims fine at slow speeds but wants to roll rt. at high speeds.
when you trim it out for high speed then it will roll left at slow.
We don't see a warp or an incedence prob. with the wing.
Does anyone else know of or have this problem? or the best way to find it and fix it?
It sure would help before i start mine.
Chas
Chas
It sounds like a definite wing problem be sure to ckeck the incedence on the inside and outside of wing to se if there is a twist I bet you will find something not right there.Or this might sound stupid but I see it alot, check the aileron trim and make sure with it trimed out the left and right are equal amounts but oposite trim in othere words one is flat and the other is down or up.
Darin
Darin
