 Twist or tribute >
Twist or tribute
Twist or tribute
Old 12-30-2007 | 09:46 PM
Default Twist or tribute
in your opinon which of these plane is better?
http://www.horizonhobby.com/Products...ProdID=HAN2950
http://www.horizonhobby.com/Products...ProdID=HAN2875
Old 12-30-2007 | 10:16 PM
Default RE: Twist or tribute
I have owned both and in my opinion the Tribute is the much better choice as far as flight performance. It is lighter, will be far more powerful without spending too much on an engine, and doesn't have any bad flight tendencies. The one I flew today has a magnum 52 four stroke on it which is just about right for it. The twist will hover and do some 3D but the tribute is actually good at 3d. It harriers upright without wing-rock unlike the twist. Knife edge flight with the tribute is also much much better on the tribute. No mixing required for great knife edge flight. The twist will need major elevator and aileron correction. The only drawback on the tribute is it is weak right behind the canopy area but it is easy to re-enforce.
Old 12-31-2007 | 11:37 AM
Walt and Sage's Avatar
The Tribute is the best 40 size 3d plane I have ever owned
BUT:
They are VERY week , mainly the fus...
After 3 planes I moved on..
Was using Webra 36 with a Moose can.. WILD !!!!
Walt..
P/s Have a Twist with 562 flights on it and a Twist 150 with an OS160FX
with 44 flights on it...
Old 12-31-2007 | 12:27 PM
seemefly_1's Avatar
wow you counted that or is that a guess
Old 12-31-2007 | 03:58 PM
oops.... [:@]
Old 12-31-2007 | 07:08 PM
octanehuffer's Avatar
Biuld the Tribute as in the thread and do my rudder pull pull setup and you wont be disapointed. The Twist will be left in the dust compared to the Tribute.
Adam
Old 12-31-2007 | 08:55 PM
linkadrip's Avatar
I love my twist PNP and the tribute is ugle IMO. But i dont Know anything about the tribute So i cant really compare but the Twist has a dedicated thread with alot of cool people. If anyhting it worth owning the twist just to be part of the club.
Old 01-01-2008 | 09:39 AM
ORIGINAL: seemefly_1
YES, I counted EACH flight...Log in at the end of the day..
May be off 1-5 but VERY CLOSE....
Old 01-01-2008 | 11:19 AM
do you have a link i can use to get to it?
Old 01-01-2008 | 12:50 PM
Daniel Z's Avatar
From: SantiagoReg Metropolitana, Providencia, CHILE
twist is an old design it is just a big wing, just floats arround, but it is no serious 3d plane
