 3d Prop? >
3d Prop?
3d Prop?
Old 01-21-2008 | 10:45 PM
Default 3d Prop?
I'm not very familiar with 3d propellers or if there is even a difference. What would I need to use for a 4-stroke .70 on a plane thats 5.5 pounds. 54" Wingspan...
Old 01-21-2008 | 10:55 PM
Iflyglow's Avatar
My Feedback: (79)
Default RE: 3d Prop?
3D prop useally means low pitch, and sometimes wide blade. A 14-4 APC should do the trick.
Old 01-22-2008 | 12:42 AM
I think a 14x4 is going to be a little too big for a 70. Thats what I run on my saito 82. On my YS 63 I run a 13x4w. Thats what I would start with if I were you.
Old 01-22-2008 | 02:09 AM
octanehuffer's Avatar
13x4
Old 01-22-2008 | 04:11 PM
70 is a bit weak for a 5.5 pound 3D plane, I had a 82 on one in that range and it would 3d, pulled out of hover very slow, no reserve(I now fly the Saito 100 on that bird).
Also try 6 pitch props in the 13-14 inch range. Many perfer 6 pitch over 4 pitch, I switch between the two.
