 dual conversion question >
Old 01-31-2008 | 12:36 PM
MetallicaJunkie's Avatar
Default dual conversion question
i have a dual conversion receiver, and a single conv. tx module, i cant get them to communicate ... is there a compatability issue?
Old 01-31-2008 | 04:05 PM
BarracudaHockey's Avatar
Default RE: dual conversion question
There's no such thing as a single or dual conversion transmitter module. Conversion (or heterodyning) is purely a factor of how the receiver handles the incoming signal to reduce its frequency to a useable number.
They must be on the same channel, and same shift (jr and futaba are opposite shift)
Old 01-31-2008 | 04:39 PM
they both must also be fm or pcm some tx will put out either you just set it to one or the other( i got a new pcm receiver same brand and channel as my tx and it wouldnt communicate till i changed my tx to output pcm)
Old 01-31-2008 | 05:23 PM
PCM and PPM both use FM, just so you know.
Old 02-01-2008 | 04:41 PM
they may both use fm but if you have your tx set on ppm and have an pcm receiver it will not work
Old 02-01-2008 | 04:44 PM
sorry for the double post
