 Front Yard 3D+Video >
Front Yard 3D+Video
Front Yard 3D+Video
Old 08-28-2003 | 12:04 AM
  #226
Default Front Yard 3D+Video
Hey, your pic gives me an idea for something cool. I'll post a pic if I do it or tell you what if I don't. Glad to hear you are doing good with that battery.
Dan
Old 08-28-2003 | 12:34 AM
  #227
Av8er Tim's Avatar
Dan - The E-Tec 1200 Lipos are good up to 12 amp bursts (10c) and work fine at around 6-8c Run time is a bit reduced at the higher amp draws, but 90% of the 3D type flying done with these small airframes is well below 8c on the E-Tecs. I have not had a problem with motor life with the 3s E-Tecs with a stock timed motor (re-timed, yes, they draw too many amps). Actually, the motors last longer than on my Slow Stick with 8 HE cells. The Kokam Lipos cannot handle the amp draws that the E-Tecs can. If you want even more amp capacity, the Thunder Power Lipos are beyond the E-Tecs.
With the ET lipos, a stock motor, 12x6 prop, "D" gearing I can get over 20 min flights and the pack and motor are quite warm, but nowhere near the temp of my NiMh packs (and that is during 90-100 degree outside air temps)
Now, I'm not saying it's not pushing the motor, it is. Motor life varies considerably. Remember these are probably 50-75 cent (wholesale) motors. They are built in huge quantities and quality is not job one... I've had stock motors burn up in 2 flights, and I've had stock motors last over 100 flights. It's the luck of the draw with these Mabuchi motors.
Brushless is the way to go, but the stock combo is still a potent power choice.
Tim
Old 08-28-2003 | 11:56 PM
  #228
Default Fan fold
Does anyone know if Green Guard 1/4" fan fold will work? This is what the local lumber yard has. It has a perforated surface. Thanks for the help. Tom
Old 08-29-2003 | 02:54 AM
  #229
Av8er Tim's Avatar
That stuff is pretty heavy. I'd try to find the blue fan fold. If you can't find that, I'd get some 6mm Depron from www.depronusa.com
Tim
Old 09-03-2003 | 01:56 AM
  #230
Av8er Tim's Avatar
OK guys, here's a sneak peek at what's to come from the foamyfactory skunkworks...
Yak 54
WS - 36"
Power - GWS EPS350C-DS (6.6:1)
Prop - GWS 12x6
Batt - 8 Sanyo AAA 720ma NiMh
Brushless set-up
Same as above with Razor 350 and 3s1p 1200ma E-Tec Lipo
Same set-up as the 3DX and 30" Ultimate bipe.
Tim H.
Old 09-03-2003 | 02:07 AM
  #231
Tim,
Yak looks cool. Need to go flying again. I'm on airframe #3 with my edges.
Mike
Old 09-03-2003 | 02:39 AM
  #232
I am planning on building one of these, How did you do the colors on that Yak? That looks awesome. This may take a while because I want all of the 'spensive stuff . I want the brushless and Lipos which make this an expensive little foamy.
Old 09-03-2003 | 03:33 AM
  #233
Av8er Tim's Avatar
Paint pens from Hobby Lobby. Brushless is worth every penny...
Mike - I'll be out of town thurs-sun. Shoot me an email this weekend and we'll figure it out. Oh, BTW, can you order no wind...
Tim
PS - Here is mycamel's (Mike H.) Edge #1 video www.foamyfactory.com/videos.htm Way cool Sponge Bob paint scheme
Old 09-03-2003 | 12:10 PM
  #234
Here's a shot of my first 3DX doing what it does best. Razor RZ350, GWS 300C-DS, E-Tec 1200 3s1p, Hitec HS-50's, Hitec Feather receiver. All Up Weight 11 oz.
PlanesInsane
Gilbert, AZ
Old 09-03-2003 | 02:54 PM
  #235
My Feedback: (50)
hey tim,when can we hope for plans?,It looks great!!
Old 09-03-2003 | 03:53 PM
  #236
Av8er Tim's Avatar
I'd say 1 to 2 weeks for the Yak 54 plans...
PlaneInsane - Looks awsome! Woooo Hoooooo!!!!!
Tim
Old 09-03-2003 | 11:21 PM
  #237
Geez PI- where are you? Never seen grass that green here Nice nice pic, too. These things are great! Looks like you are having fun with em, too. We gotta get together some time. I think I have told you about the Chandler Bowl, right?
Dan
PS: I noticed a few other guys here are RCGroups members. Are you having trouble getting on right now? I think Ezonemag and RCGroups are down (makes sense, I think they are off the same server.)
Old 09-04-2003 | 11:27 PM
  #238
SKYPYRO - Chandler bowl? Can you tell me where this is and when you area out there flying? Thanks
Old 09-05-2003 | 02:55 PM
  #239
Av8er Tim's Avatar
Hey guys,
I just posted a new 30" UB video. It's pretty wild! Check it out.
Its the video at the bottom of the page www.foamyfactory.com/videos.htm
Tim
Old 09-06-2003 | 12:14 AM
  #240
Post got deleted, long story short, by accident. Here is the link for how to get to the Chandler Bowl, and the rules of regulations there.
http://www.rcgroups.com/forums/showt...5&pagenumber=1
Tim- as always, another great production! You have really improved as a pilot since those first couple of videos. Especially with that "constant Kansas wind."
Dan
Old 09-06-2003 | 12:22 AM
  #241
3D Romeo's Avatar
My Feedback: (111)
PlanesInsane
Your plane looks blue & white...what did you use to color it?
It looks Great!!!
Old 09-09-2003 | 08:35 PM
  #242
Default RE: Front Yard 3D+Video
Geez, it is almost impossible to find your old threads now. I really wish they would have kept it the same, but it's too late now. Dang. So, did anyone else survive the switch?
Edit: ok, this was just an off topic rant. Anyways, are any other 3DX flyers in the Gilbert area? I would love to fly with you sometime.
Dan
Old 09-10-2003 | 12:24 PM
  #243
Hi Guys/gals, Just cut my 3dx out of foamcore board.( paper covered foam) After I peeled off the paper, my thickness was just under 5 mills so I decided to cover all sides with solarfilm light. It is a low temp very light iron on covering that makes the foam very strong without adding very much weight. ( .6 oz. per square yard!!) Results have been excellent. It comes in tons of colours and applies at 80 to 100 degrees. I will post some pics as I finnish. Thanks to the 3d ghuru for the plans. MAD out.
Old 09-10-2003 | 12:30 PM
  #244
Mark, I know I replied to this once before but it disappeared. Plane was painted with PlastiKote from the autoparts store.
Old 09-12-2003 | 02:38 PM
  #245
Av8er Tim's Avatar
So far, looks like the thread survided the switch. I know more cahnges are being made, hopefuly no surprises...
Tim[8D]
Old 09-12-2003 | 05:27 PM
  #246
sloanfs's Avatar
Hi Tim, I downloaded the video, very impressive, you're making it look too easy.
I downloaded the plans from your website, Thanks!! It will be a nice indoor plane for this winter.
Dave
Old 09-15-2003 | 02:05 PM
  #247
Anyone tried the MPJet 25/35-20 on the 3DX yet? Seems an incredible deal at $50 for the motor, which includes a 4:1 gearbox. $125 with a Phoenix25 ESC from http://www.mountainmodels.com The hobby lobby website http://www.hobby-lobby.com/brushless_mpjet.htm claims 26oz of thrust with 8 cells and a 10x6. Seems a good fit for teh 3DX, no?
Old 10-02-2003 | 10:21 PM
  #248
Av8er Tim's Avatar
Jimmy - It should work fine. However, I have not tried it...
OK guys, I just posted a new Yak 54 video. It rocks! www.foamyfactory.com/videos.htm
Tim
Old 10-03-2003 | 05:27 AM
  #249
My Feedback: (20)
Hey Tim
The Yak looks awesome! Your not having to much fun are you? Good job bud!
Old 10-05-2003 | 06:05 PM
  #250
...5 months later...
Hey, this stuff looks neat! I'm going to have to try one of those.
So get the blue stuff? Not the pink stuff?? 'Cause the blue is lighter???
