 OS12AX and Perry Pump >
Old 01-02-2009 | 06:15 AM
Default OS12AX and Perry Pump
I am just about to purchase an OS120AX to go into a Funtana X100 and was wondering whether to also purchase a Perry Fuel Pump for the motor (Not For Smoke) the one that takes its crankcase pressure by drilling a hole in the rear back plate of the motor.
Are they any good, and would the engine or I for that matter benefit from one fitted.
An early response would be appreciated as it may be as soon as this afternoon, if no answer by then may delay purchase of pump but still get the motor.
Simon
Old 01-02-2009 | 08:31 AM
Zippi's Avatar
My Feedback: (10)
Default RE: OS12AX and Perry Pump
Diamond Dust,
I had an OS 120AX in a Funtana X100 and did not use a pump. I was running a Bisson pitts style muffler and an APC 17X6 prop. Unless your planning on moving the fuel tank way back on the CG there is not need for a pump.
ID:	1101451   Click image for larger version
ID:	1101452   Click image for larger version
Old 01-02-2009 | 08:44 AM
Thanks for that Zippi, What size spinner is that you have, and was it powerful enough with the 120
Old 01-02-2009 | 08:56 AM
Zippi's Avatar
My Feedback: (10)
ORIGINAL: Diamond Dust
The spinner was the size that was suggested in the manual if I recall. The OS 120AX will give you unlimited vertical.
Old 01-02-2009 | 11:36 AM
daveopam's Avatar
My Feedback: (9)
This is the understatment of the new year. David
Old 01-02-2009 | 12:28 PM
MetallicaJunkie's Avatar
i have a 120ax on a 120 wild hare edge, and dont see a need for a pump
Old 01-02-2009 | 03:39 PM
Thanks everyone. I have purchased the engine today, looks a nice piece of kit. Took your advice and didn't bother with the pump. I am going to nail it to piece of wood and run a couple of tanks thru it tomorrow.
Cheers
Simon
Old 01-13-2009 | 01:52 PM
the o.s 120 ax does defonately have enough power to hover this plane, heres a pic:
File Type: pdf
Old 01-19-2009 | 10:01 AM
Daniel Z's Avatar
From: SantiagoReg Metropolitana, Providencia, CHILE
I would think to use a tower or performance especialities or Jett muffler instead of a pump
Old 01-19-2009 | 05:13 PM
Javier-RCU's Avatar
I am using a Perry pump with a mid fuse mounted tank (on cg) in my Extra 300. Great performance. I think the Perry is a good adition to this excelent engine.
